06 H3 front binding and locking
Old 06-29-2015, 03:13 PM
h3mb's Avatar
Default 06 H3 front binding and locking
Occasionally my front end is binding and locking up (well almost) while driving. Typically know it's going to happen when I apply the break and get a slight kickback on the pedal. Afterwards the front end binds, clunks, sounds like it's going to break and then releases. This can happen for several attempts at moving forward then will eventually stop. Replaced left cv drive shaft, checked the front main drive shaft no problem. Right cv seems ok. Happens sometime while going along at 30-40mph. Scary. Any ideas. ABS, traction, and stability warnings are on. When this happens these warnings do not display.
Old 06-29-2015, 04:47 PM
rascole's Avatar
Transfer case plastic shift for is my first guess. I had a similar issue and the cheap fork was it, replaced with metal fork and all is well.
Old 06-30-2015, 08:57 AM
Are you using OEM brake rotors and pads up front? Have you had a wheel off for a good look at them?
When was the last time you changed the front diff lube? I would drain it and see what is in the lube to see if there is any shiny metal flakes.
Messed up brake calipers can stick and act as you describe, or a toasted front diff ring gear can cross up when braking (the old wax and wane thing) and cause noise, clunking... until it breaks.
wvuengr12
09-14-2020 02:06 PM
Poconosteve
03-12-2014 07:31 PM
TexH3
06-20-2008 09:50 PM
Nxsov180db
04-30-2008 09:55 PM
duckstu
24
04-17-2008 08:07 PM
Quick Reply: 06 H3 front binding and locking
