Oil interval change?
Old Jun 27, 2015 | 04:45 PM
Piranha's Avatar
Default Oil interval change?
My oil indicator is at 39%... do you guys let it go to 0% or 10% Just curious, thanks!!
Old Jun 27, 2015 | 06:48 PM
LoJac963's Avatar
I let mine get down to around 5% before I change the oil. Usually it will put me around 5,000 miles between changes. I only use synthetic so I'm not concerned going that far between changes. I also keep my air filter clean and run a pre-filter.
Old Jun 28, 2015 | 10:02 AM
Synthetickiller's Avatar
In every H2 I've owned, using full synthetic, I allow 2 intervals to pass before changing. Never had any issues with doing that.
Old Jun 28, 2015 | 10:08 AM
Piranha's Avatar
Thanks guys! Yeah I'm using Mobil One 5-30 High Mileage since it has extra zddp
Old Jun 28, 2015 | 10:11 PM
hmer's Avatar
i have 10% left now using mobil1 full synthetic and my last oil change was just over 12k miles ago . a few of my friends do 8k per oil change using full synthetic even if there is oil life left on the DTC and must of their H2 are going over 200k miles already
Old Jun 29, 2015 | 08:08 AM
calif phil's Avatar
I do 20% or every 4000 miles. Oil changes are cheap and I also lube the chassis and rotate the tires at every oil change. I do it myself so it doesn't cost me anything in labor.
Old Jun 29, 2015 | 08:46 AM
H2Miami's Avatar
I use mobil 1 full synthetic and filter which is good up to 15,000 miles but anyway i change the oil every 5000 . I rather to spend a few bucks in oil than mechanical issues
Old Jun 29, 2015 | 10:15 AM
Might as well save money & go 100% dino oil. Changing every 5000 is just a waste & goes against the benefits of using synthetic in the first place. Save some of the oil & have Blackstone labs doing an oil analysis. If you can get 10k miles out of it, why not do it. If it's clean, there's no downside.
Old Jun 30, 2015 | 09:50 AM
Piranha's Avatar
Yeah I plan on doing a blackstone analysis on mine when the indicator hits 10%... will post up here
Old Jun 30, 2015 | 09:59 AM
H2Miami's Avatar
You are right but cause I have to change my other car (work honda element) Every 5000 miles due to the Fl high temp 100°+ and high avg speed then I just make both oil changes together .
Mantenience is cheaper than the mechanics My truck is 100k miles and the engine still works as a new truck .
rhill20
Jul 1, 2013 12:23 PM
ftc-garage
Dec 29, 2012 08:38 AM
drtom
Jan 17, 2011 09:23 PM
hummer07
Nov 18, 2008 10:46 AM
Intercooled
Sep 19, 2005 12:41 PM
