Ok, really dumb question...how to exit H3X driver seat?
Have never encountered this with a vehicle before, but here we go.....
When I get out of the vehicle from the driver side seat on my H3X, my weight pops the left side plastic seat panel loose. This is the panel that contains/covers the seat adjustment and heated seat controls. When it pops loose, it ALWAYS bumps the seat heater into the upper position (high setting). I don't always want the seat heater on! lol.
I have popped the panel back in place several times. I have analyzed how I get out of the vehicle. I just kind of roll out. I have tried spinning 90 degrees, then stepping on the nerf bars. I still pop the panel loose.
BTW, I am 6' 1" and 225 pounds.
Considering trying to remove that panel. Don't know what else to do. This is crazy. Thoughts?
Take a sharp utility knife and carefully trim the opening in the panel above the switch. It doesn't require a lot of clearance so just trim a small amount at a time until the problem goes away. A Dremmel will work, but there is a risk of accidentally damaging the switch and it is easy to remove more material than necessary.
There was a thread sometime back that dealt with this issue. https://www.hummerforums.com/forum/h...-just-me-5541/
It required the addition of a screw to hold the panel in place, and somebody on the forum posted a pic of the screw location but I can't find it.
I posted the photo. I also removed the trim price and used a dremmel around the top of the opening for the seat heater switch.
I'll see if I can take a photo and post it. The dealership did the screw via a TSB from GM.
