Driving without Front Shaft
Old 05-17-2015, 07:40 PM
Hooty-Hoo's Avatar
Default Driving without Front Shaft
Hey guys. Wheeling this weekend and started hearing a steady clunk at low speed. Thought it was the half shaft cv joint but after I got her home, discovered the rear joint of the front shaft was toast. I removed the front shaft to get it repaired tomorrow and then wondered, can I drive it without the front shaft? Will the computer give me hell because it doesn't get a signal in the front diff? I was talking to my neighbor who used to have a jeep and he said that he used to drive that without the front shaft to increase his gas mileage. Just wondering. Thanks.
Old 05-17-2015, 08:55 PM
happythree's Avatar
ya need to be in hi lock
Old 05-18-2015, 10:40 AM
If you did not change to 4hi lock before removal of the front prop shaft you will have to fool the computer by switching while the key is in the run position, do not start it.
Old 05-18-2015, 11:09 PM
Hooty-Hoo's Avatar
That would have been good info yesterday!
Old 05-19-2015, 05:44 PM
rascole's Avatar
How did it run?
Old 12-08-2020, 01:00 AM
Engine09's Avatar
2006 H3. Currently have my front drive shaft removed, waiting for a replacement to come in.
Switched to HI lock while engine was off to "trick" the computer, no problem and all the power went to rear wheels. 100 feet down the road the transfer case disengages out of lock on it's own and it coasts to a stop with all power trying to go to the front which has no drive shaft. 4 Hi lock light stays on but for some reason lock does not stay engaged.
I repeat the 4 HI regular to 4 HI lock switch, same thing, 100 feet down the road it disengages out of lock and it coasts to a stop. I've read that guys have driven H3s without a front drive shaft in 4 HI Lock, what is it that is preventing my H3 from staying in 4 HI lock?
Next time I really need 4 HI lock I would like it to work, wondering what is failing and needs to be replaced, thanks!
Old 12-08-2020, 06:33 AM
Wink
Good morning,
You are posting in a 5.5 year old thread. That's a No-No here.
Please start a new thread with the exact info above and include year and any other maintenance information you have done to the effected area.
You have a worn plastic shift fork in your transfer case most likely.
Old 12-08-2020, 10:57 AM
Engine09's Avatar
Just saw that sticky thread after you mentioned it, usually message boards get annoyed when too many new threads are started. I've been given **** on other boards for not using an existing thread where similar info is posted but I see what's prefered, point taken!
anderson_h3
Private 'Wanted' Classifieds
11-03-2013 07:26 PM
adonatz
04-25-2011 04:51 AM
theBroken
16
02-13-2010 01:37 AM
theBroken
11-07-2009 02:40 PM
Quick Reply: Driving without Front Shaft
