Can't get the Passenger side axle back in
Old 04-22-2017, 04:46 PM
kmo233's Avatar
Default Can't get the Passenger side axle back in
2008 Hummer H3 - Base...Need Help!! I removed the passenger side drive axle off with very little trouble but when I tried to install the replacement axle the shaft inside the differential moved off center. I place a rod inside and tried to force it to move but it wouldn't budge. I placed it in Neutral and lifted both tires off the ground and tried to rotate the front drive shaft but it would not budge. Any ideas what I can do to center that shaft?
<img src="https://lh3.google.com/u/0/d/0B189pIxR0Aupd1Z4d2lzY2E1dGxoQkUtTnJlQ1NhVS1UTHdJ= w1366-h630-iv1" alt="Displaying 20170416_181105.jpg"/>
Old 04-23-2017, 12:59 AM
Happy Hummer's Avatar
Did you get this worked out? Pics?
Old 04-24-2017, 09:35 AM
I fail to understand the issue. When you put the half shaft back in, you turn it fwd/back to line up the splines and push it in until it clicks? Then bolt up the outside.
Old 04-24-2017, 10:03 AM
kmo233's Avatar
Hopefully I can get these pictures to upload. The problem is when I push the half shaft into the differential opening the splines are off center (to the right) and won't move side to side so I can slide the half shaft all the way in.
Attached Thumbnails Can't get the Passenger side axle back in-20170416_181107.jpg
Old 04-24-2017, 10:12 AM
kmo233's Avatar
This might be better!
Attached Thumbnails Can't get the Passenger side axle back in-screenshot_20170423-020505.png
Old 04-24-2017, 11:35 AM
happythree's Avatar
you might be looking at other gears. i think doc is right, got to wiggle it and push past the lock ring? pic looks good.
i havnt done one in yrs, a pontiac minivan, had to push hard.
motley1987
01-10-2022 01:08 AM
wpage
01-20-2016 08:04 AM
LooseMoose
08-27-2010 10:29 PM
jash3
02-17-2010 03:22 PM
dilo2001gt
16
10-19-2006 05:59 PM
Quick Reply: Can't get the Passenger side axle back in
