Driver side of H3 sits a little lower than passenger side
Old Aug 27, 2010 | 08:19 AM
LooseMoose's Avatar
Default Driver side of H3 sits a little lower than passenger side
When I stand back and look at my vehicle, I notice it slants a little to the driver side and sits a little bit lower than the passenger. Is this something with the suspension coils? Is it just heavier on that side? Any thoughts or answers would be much appreciated!
Old Aug 27, 2010 | 08:21 AM
85_305's Avatar
Banned
lol thats funny.
When these truck rolled out of the factory, the torsion bars are at different measurements (rates). Every single truck has different readings on all ends. Funky isn't it?
But crank your torsion bars an additional 2" and reap the benefits (and a level truck).
Old Aug 27, 2010 | 09:10 AM
thermalfrost's Avatar
Mine's the same way. Drivers side sits lower than the passenger side. From the back, the difference looks substantial.
Old Aug 27, 2010 | 09:12 AM
85_305's Avatar
Banned
Yep this is very common from the factory. Dunno how it happens or why. But it does.
Old Aug 27, 2010 | 11:42 AM
It's called the GM lean, has to do with strapping down the truck for rail shipment and fade rate of a brand new T Bar. You can search that as well.
Measure both sides at the finder to the ground and adjust your T Bar bolt tightening the low side (read all the levelling threads for a how to) until it is level accross. You need a 1 1/16" socket with long handled wrench and 5-10 minutes.
Old Aug 27, 2010 | 12:13 PM
85_305's Avatar
Banned
LOL are you serious Doc??? Why don't other cars have similar issues???
Old Aug 27, 2010 | 01:02 PM
Broken Halo's Avatar
I just posted a thread about a week ago with the same problem. Mine is 7/8" lower on the driver's side rear, then the passenger side rear. The front is perfect, side to side. I thought possibly cranking the t-bar would correct this, but, then it would throw off my otherwise perfectly leveled front end. Could a reason for this 'lean' in our H3's have something to do with the fuel tank being mounted entirely on the driver's side, instead of being centered laterally? 23 gal's. of fuel adds approx. another 200lbs. of weight to the driver's side. Don't know if GM compensated for this with a higher spring rate on the driver's side or not, but, then again if they did, it seems with an empty tank, our H3's would lean the other way!
Old Aug 27, 2010 | 02:01 PM
85_305's Avatar
Banned
Yes cranking the tbars would help fix the problem. I'd take Docs word though; he's a squared away dude.
Old Aug 27, 2010 | 10:29 PM
whatever's Avatar
That dude is determined to **** off all the adults.
Bartacus
May 26, 2012 10:35 AM
Pauldy
May 4, 2012 02:15 PM
stabwound17
18
Apr 22, 2011 08:31 AM
Surfcastr82
Nov 24, 2009 06:52 AM
Nick119
Jan 9, 2008 10:05 AM
