4 high and low buttons dont work!
Old 11-27-2014, 07:54 PM
hummG's Avatar
Default 4 high and low buttons dont work!
just got the H3 and love it but the 4 high and low buttons don't work, when I press them nothing happends, no noises no lights nothing. when I start it up they light up but when I press 4 high lock its like theres no connection.
Old 11-27-2014, 08:24 PM
Happy Hummer's Avatar
This is well documented on this and other sites dealing with h3's.
1 actuator
2 tcm
3 buttons
Just some thoughts.
Chris
Old 11-28-2014, 09:11 AM
happythree's Avatar
Default just got the H3
my first thought is always,go back to to seller and ask them if it did that.
a dealer should check/fix it?
Old 11-28-2014, 06:48 PM
hummG's Avatar
any thouhts what to do never happened in the past with the other owners...could the buttons be fried?
Old 11-28-2014, 06:53 PM
happythree's Avatar
make sure all connectors are plugged on right.
find another hummer guy to check it side by side.
Old 11-29-2014, 07:29 AM
Year, mileage options.
Have you read the owners manual on proper operation of the controls? If so then try to get into 4lo. That is when you will hear a click.
Old 11-30-2014, 04:20 PM
hummG's Avatar
i have a 2007 h3 base just the three 4x4 buttons and traction/stability control..no owners manual but i looked on up an it says to put it in neutral then press the button but i got nothing
Old 12-02-2014, 04:10 PM
You must be in 4HI Lock first then neutral 0-5mph and select the 4lo position.
If that does not work then you have a shift fork issue. Search that topic. 100s of posts if it won't go into 4lo once you follow the directions above.
Old 03-30-2015, 09:55 PM
BradRoppe's Avatar
I have a somewhat similar issue right now, BUT my normal 60/40 AWD is working but when I try 4 hi lock the button does not blink, nor does 4 hi lock engage. No CEL on or anything. Any thread suggestions or advice on any of our issues? 4 Lo works just fine. 4 hi is the only one not working. No idea. If the transfer case motor is bad would it still make it to 4 Lo just fine? Or another issue? HELP
hummG
11-27-2014 07:50 PM
Kinder82
04-04-2013 08:30 PM
PSYCHOBOY
06-01-2012 12:46 PM
PSYCHOBOY
06-01-2012 12:28 PM
mnext02
09-26-2011 10:45 AM
Quick Reply: 4 high and low buttons dont work!
