3.5" MAF
Old 06-11-2008, 07:01 PM
HummerKid82's Avatar
Default 3.5" MAF
Anybody know one that will work. I tried a Silverado with the 5.3, but the plugs don't match up.
Old 06-11-2008, 07:02 PM
Default RE: 3.5" MAF
Oh, and the junk yard I went to is dumb, you can't walk around. There's a parts desk that you have to tell them what you want.
Kind of hard to find stuff like I am.
Old 06-11-2008, 07:08 PM
With a little more info about exactly what you are looking for, I might be able to help ya?
I am assuming a Bosch type 3.5" MAF????
Old 06-12-2008, 04:13 AM
I'm just trying to open up the tube some. I don't understand only running 3" at the MAF if you can run 3.5" into the TB.
Old 06-12-2008, 07:34 AM
Alright, now I got ya. I know what ya mean. The inlet snorkel to the Air Filter Box is only 2.73", that is why I replaced it. The MAFs for the I5 are what I would call dedicated. You would have to redo from scratch, reconnect/rewire the connection ofyour custom MAF, and then reprogram the PCM. Lots of work and fiddling for a
de minimus gain?
I have not checked every possible MAF that may be out there, so it may be possible? Good luck brud.
Old 06-12-2008, 10:18 AM
ORIGINAL: HummerKid82
The 3" MAF probably acts as a venturi. Your ECM may get false readings resulting in an inaccurate fuel air ratio if you switch. These engineers do things for a reason... most of the time.
Old 06-12-2008, 01:48 PM
veves's Avatar
More air more = more fuel= morepower = lessmpg.
Thats why theres a restriction on the airbox
nodnarbedge
01-30-2009 04:03 PM
jumperdp
11-19-2008 02:56 PM
Gooch
07-01-2008 09:51 AM
dizzy
32
04-01-2008 04:41 PM
dizzy
10-27-2007 11:09 PM
Quick Reply: 3.5" MAF
