Battery Problems
Old 01-13-2014, 03:15 AM
Spick's Avatar
Default Battery Problems
HI,
I have a 2003 Hummer H2. Having replaced the battery 5 months ago I started noticing that it was sometimes hard to start. As the battery was under warranty I had it replaced. The very next day I had the same problem and realised that the battery may not be the problem. Having read some posts on here, not as a member, I put a meter between the Pos battery lead and Pos terminal and found that I had current being drawn by 5 fuses whilst the engine was off. TBC BATT, IPC/DIC, HVAC/ECAS, RADIO and RADIO AMP. I tried leaving them out but realised that the engine will not start with TBC BATT left out. I have also noticed today that I am hearing high revs at about 70 - 80 KPH before the automatic gearbox changes up. Could this be something to do with the electrical fault?
Can anyone help as I am currently serving in the Middle East where a good mechanic is hard to come by.
Many thanks in advance
Spick
rtwash
12-13-2013 10:45 PM
ziplineboss
12-03-2010 02:33 PM
Tim
03-23-2010 09:14 AM
Linda
10-20-2009 08:10 PM
HammerDown
21
02-19-2008 07:04 AM
Quick Reply: Battery Problems
