battery problem URGENT
Hello ! I have a Hummer h2 2003 and here is the problem. Today, when I turned off the car, the radio didn't turn off. I thought, maybe if I start the car and shut it down, it will fix. I did that, and it stays turned on. The battery light on the panel, when the engine is working is off but when I stop the engine and remove the key it stays on and the radio too. The battery light stays on. What is the problem?
Hello,
I have the same issue today with a H2 2003 too: the battery and all the onboard lights stay on when the car is turned off and the key removed, but the battery light off when I start the car.
The battery is OK (12V) and the alternator works fine.
How to verify the ignition switch before ordering a new one ?
Is there any fuse to check ?
Another idea ?
In advance thank you very much for your help.
Another idea ?
Hello,
Another idea ?
Another idea ?
Thank you for your reply.
Please, could you explain how do you disassembled the parts to access the ignition switch ?
maxvis
10-22-2012 12:40 PM
raptor0690
09-19-2009 11:27 AM
H1Intercept
07-17-2008 04:02 PM
RyanCodyH3
06-09-2008 09:56 AM
