2005 Hummer H2 Starter
Old 08-02-2012, 08:21 PM
BiG_Ze's Avatar
Unhappy 2005 Hummer H2 Starter
hi,
i have a problem and i think its a common or well known problem.
trying to get the truck started but it doesn't.... i hear a click sound. got the battery replaced but still having hard time to start.. i think its starter issue!!!
instrument panel and lights work fine "why not when it comes with a new battery"
wishing if anyone help me with starter diagram so i can start troubleshooting.
one more request... what starter bran you suggest beside the OEM...
thanking you in advance....
Old 08-02-2012, 11:17 PM
bflorin's Avatar
There is a starter relay in the fuse box in the engine compartment, try swapping that out w/ another relay.
Old 08-03-2012, 10:45 AM
BiG_Ze's Avatar
haven't thought on that.... well try
thanks
Old 08-04-2012, 08:32 PM
SafariHummerH2's Avatar
Default Starter Problem
Hello Friend,
I own an 03"
I had a similar starter problem sometime ago.
It was the screw connections on the starter itself were all coroded with rust.
I replaced the starter and literally had to break the screw connections on the starter in order to release the connecton cables.
After replacing the starter, I spray painted the screw connections to avoid corrosion or rust.
Safari Hummer H2
Old 08-10-2012, 09:03 AM
2wheelmonster's Avatar
good idea on painting the screws
SafariHummerH2
09-18-2012 11:31 AM
runfrumu
11-20-2010 07:13 PM
dilo2001gt
32
02-15-2007 01:37 AM
Rayvyn
01-21-2006 04:01 AM
Rayvyn
01-04-2006 02:40 AM
Quick Reply: 2005 Hummer H2 Starter
