2005 Hummer H2 Starter
hi,
i have a problem and i think its a common or well known problem. trying to get the truck started but it doesn't.... i hear a click sound. got the battery replaced but still having hard time to start.. i think its starter issue!!! instrument panel and lights work fine "why not when it comes with a new battery" wishing if anyone help me with starter diagram so i can start troubleshooting. one more request... what starter bran you suggest beside the OEM... thanking you in advance.... |
There is a starter relay in the fuse box in the engine compartment, try swapping that out w/ another relay.
haven't thought on that.... well try
thanks :) |
Starter Problem
Hello Friend,
I own an 03" I had a similar starter problem sometime ago. It was the screw connections on the starter itself were all coroded with rust. I replaced the starter and literally had to break the screw connections on the starter in order to release the connecton cables. After replacing the starter, I spray painted the screw connections to avoid corrosion or rust. Safari Hummer H2 |
good idea on painting the screws
