Won’t start when cold
Old 02-04-2022, 07:58 AM
Ddjones1127's Avatar
Default Won’t start when cold
I have a 2005 H2, when it gets below 30 degrees Fahrenheit it won’t start. It does nothing, no clicks, no start to turn over or crank, but like it’s just completely dead. No dash light are on, new battery, new starter ( alternator is pretty new as well) . Once the weather warms up the truck starts right up. Any ideas or similar experiences?
Old 02-04-2022, 09:53 AM
bad main ground? put a jumpe rcable from your negative battery to the chassis and or engine and see if things change.
Old 02-04-2022, 10:38 AM
I’ll try that, but I did try to jump it and it still acted like it was dead, but I was just battery to battery, so maybe it is the ground wire
Old 02-04-2022, 11:39 AM
Well, that seemed to work, jumped ground from battery to engine block and it fired right up and it’s still only 18 degrees out so it’s not warmed up enough to say the heat did it!!!!! Thanks !!!! Hoping a new ground cable fixes it for good.
SquareD
01-17-2022 08:43 PM
Humm3r
04-05-2021 01:21 PM
chrisg75077@gmail.com
11-01-2019 10:35 AM
ffmf2101
11-19-2018 08:37 AM
real7446
01-05-2008 07:47 PM
Quick Reply: Won’t start when cold
