H1 Parking Brake
Old 04-12-2014, 08:11 PM
Centauro97's Avatar
Default H1 Parking Brake
Folks,
I found a 2003 H1 that I'm interested in buying. On the test drive I couldn't set the parking brake. It had a lot of resistance to pulling the lever up. I figured either there was a trick I was missing or something was wrong. I have no idea how the knurled **** is used, if it matters.
Sorry for being such a noob, but I'd really like to join this unique group. A search didn't find an answer.
How does the parking brake work? What should I ask for prior to purchase?
Thanks to all.
Old 04-16-2014, 03:59 PM
AugerN's Avatar
The top of the parking brake turns to adjust the tension. Turn counterclockwise just enough until the brake can be applied. It is still requires a fairly firm pull even when properly adjusted. Good luck in your search!
D
2001 H-1 Wagon
Old 04-18-2014, 01:14 PM
Centauro97's Avatar
Well since I plan on buying it I'll give it a hearty yank this time. The truck is low mileage. I suspect the parking brake was never used as there is no paint wear on it at all.
Thanks for the reply.
Old 04-19-2014, 08:06 PM
Centauro97's Avatar
Thanks for the info. That worked.
Drove it home today. The injection pump looks nice and new. The PMD is right on the side. I suspect the prior owner ate that "fix" for a hot PMD.
That's one of the first upgrades, a "cooler" PMD.
And locking fuel doors since I live in a neighborhood where Prius is king.
lucky19942001
10-24-2019 12:41 PM
khoolhandz
02-19-2018 05:31 PM
wfturner
19
06-23-2011 07:49 AM
susies59
07-10-2010 02:42 PM
chsnprodigy
06-25-2007 11:10 AM
Quick Reply: H1 Parking Brake
