Front door speakers not working
Old 05-29-2018, 04:50 PM
Mitchell Glover's Avatar
Default Front door speakers not working
I have a 2006 h3 Hummer with the moonso sound system and I am currently replacing all the factory speakers but the front door speakers aren’t working. The back door and tweeters work and I even put in new speakers and they don’t play any music. This is also the case when the factory speakers are in. They won’t play any music. Anybody with any comments or suggestions on why it’s doing this?
Old 05-30-2018, 07:30 AM
Stupid Question. Are the fade settings set to the middle position?
Old 05-30-2018, 11:44 AM
atvspeed4's Avatar
If the fade in fact, is in the right position, I was having a similar issue in one of our 2006 and it ended up being a loose connection in the large connector between the door and body that has a handle to push down when it is seated properly to lock it in. I could wiggle the connector and get the speakers to work.
Old 05-30-2018, 01:30 PM
yes the fade is in the middle
Old 05-30-2018, 01:34 PM
thank you I will try that!
Old 05-30-2018, 03:09 PM
where is this connection located at?
Old 05-26-2021, 09:00 AM
Originally Posted by akbaradeli
When all of the speakers in a car audio system all stop working at once, the problem is usually in the head unit, in the amp, or in the wiring. In some cases, an issue with the wiring between the head unit and a single speaker can even cause all of the speakers in an entire car audio system to cut out at once.
Welcome to HF. Please STOP digging up OLD Threads, not how we do it here. READ: Old Threads/'Necro-Bumping'
TxHummer07
03-22-2015 11:02 AM
JensH2
12-14-2013 02:27 PM
AJPhilips24
09-11-2011 02:51 PM
2007H3
12-11-2007 10:28 PM
96TL
01-29-2007 03:48 PM
Quick Reply: Front door speakers not working
