Front door speakers not working
Old May 29, 2018 | 04:50 PM
Mitchell Glover's Avatar
Default Front door speakers not working
I have a 2006 h3 Hummer with the moonso sound system and I am currently replacing all the factory speakers but the front door speakers aren’t working. The back door and tweeters work and I even put in new speakers and they don’t play any music. This is also the case when the factory speakers are in. They won’t play any music. Anybody with any comments or suggestions on why it’s doing this?
Old May 30, 2018 | 07:30 AM
Stupid Question. Are the fade settings set to the middle position?
Old May 30, 2018 | 11:44 AM
atvspeed4's Avatar
If the fade in fact, is in the right position, I was having a similar issue in one of our 2006 and it ended up being a loose connection in the large connector between the door and body that has a handle to push down when it is seated properly to lock it in. I could wiggle the connector and get the speakers to work.
Old May 30, 2018 | 01:30 PM
yes the fade is in the middle
Old May 30, 2018 | 01:34 PM
thank you I will try that!
Old May 30, 2018 | 03:09 PM
where is this connection located at?
Old May 26, 2021 | 09:00 AM
Originally Posted by akbaradeli
When all of the speakers in a car audio system all stop working at once, the problem is usually in the head unit, in the amp, or in the wiring. In some cases, an issue with the wiring between the head unit and a single speaker can even cause all of the speakers in an entire car audio system to cut out at once.
Welcome to HF. Please STOP digging up OLD Threads, not how we do it here. READ: Old Threads/'Necro-Bumping'
JensH2
Sep 14, 2025 08:52 AM
TxHummer07
Mar 22, 2015 11:02 AM
AJPhilips24
Sep 11, 2011 02:51 PM
2007H3
Dec 11, 2007 10:28 PM
96TL
Jan 29, 2007 03:48 PM
