Need some help, my battery is draining :(
When I am not driving the car in 3-4 days, the battery is dead, I have to start the car with a booster, then it starts like normal. Checked the dynamo, it works fine, got a brand new ACDelco battery 3 weeks ago, it still drains. I got a message in display last week - "service air suspension", but only once, then it dissapeared. Its a 2003 model. Does anybody have some thougts on what the problem might be? It is sooo frustrating. I appreciate ALL answers and tips. Greetings from Norway!
Yes. Especially the older analog ones that cannot even be used anymore. Just pull the VCIM (Vehicle Communications Interface Module) fuse from the fusebox under the hood. That kills the power to the onstar system.
Next step would be to start testing for parasitic drain. Few ways to go about that and a few things to be aware of. Search online for how to test for that. Main thing to be aware of is on the H2 (and many other GM vehicles) after you shut it off the BCM and climate modules do stay active for a few hours. They do not draw much and not enough to kill the battery in 3 days though. But if you are using a clamp meter or something to check for amperage draw you will get some readings from those for a few hours after you shut the truck off.
As always Mixman is spot on with his suggestions. I will add that I had the same issue on my '03 and it was the electrical portion of the ignition switch. It would not shut off all the way and it was acting like you left the key on. Replaced the switch and all was well.
kauaih1
06-25-2013 09:10 AM
