2007 H3 Gear shift lights not working
Our 2007 H3 gear shift light will not illuminate. The truck is locked in park and will not come out of park.
additionally, the door locks have started locking and unlocking themselves when the car is turned on.
Any my ideas as to what is wrong?
BCM? Broken wire? Bad fuse? Brake switch? Transmission range switch? I would start by checking the fuses with a test light to make sure there is power going to the fuses. Then check those door switches. I have a feeling there is broken connection somewhere. Maybe even check your relays. Hope this helps.
You still using the POS OEM Battery Terminal Connectors?
yes and yes. We had an awful leak and finally fixed the drain tubes. Still using the terminal connectors. What is the connection between these 2 and the door lock gremlin?
A friend of mine had very similar problems to what you describe (add in wipers turning on and off by themselves), it was a wet BCM as it all started after a couple days rain when the sunroof drains were plugged and flooded the passenger floor.
The Battery Terminal Connectors are a known problem, the all fail eventually, and cause other electrical Gremlins.
jamiw
02-24-2016 11:22 AM
JensH2
12-14-2013 02:27 PM
dr_tao
09-08-2012 11:30 PM
JMGPhila
12-09-2010 01:13 AM
