Wont go into four wheel drive HELP!
Old Jan 26, 2013 | 07:46 AM
bhsanchez72's Avatar
Default Wont go into four wheel drive HELP!
I have a 2005 Hummer H2 and when I go to put it into 4 hi lock the light just keeps flashing and it never completes the switch. Any ideas to how to fix this. Thanks in advance.
Old Jan 26, 2013 | 12:42 PM
Asanti's Avatar
I have a 2008 H2 and found that I couldn't switch out of the "everyday" setting for 4 wheel drive. An inspection revealed that the transfer case mode selector switch had shorted. The switch itself cost $342.96 and labor was one hour. The switch number was 25878427:switch (04563-CT). I hope this helps.
Old Jan 26, 2013 | 01:06 PM
H2CANEPADESIGN's Avatar
Pretty much only two things it can be. Asanti just listed one of them. the other is the actuator motor bolted into the side of the t-case. Mine when bad, it was about 160 dollars to replace. took two minutes to bolt in myself and voila. problem solved.
Old Jan 26, 2013 | 07:02 PM
Is there any way you can check to see which it is? The motor or the switch.
Old Jan 26, 2013 | 09:15 PM
fyr145's Avatar
Default 4wd
I know this may be obvious but just in case.....
when switching modes, be sure that you are in neutral first.
simota1
Nov 24, 2021 12:45 PM
tbraly
Apr 19, 2014 08:36 AM
DNA
Oct 22, 2010 08:30 PM
NJTEX
Nov 10, 2007 10:26 PM
alphafourwheeldrive
Feb 13, 2007 07:33 PM
