Which wire do I use?
Old Nov 19, 2008 | 03:44 AM
rhino_160's Avatar
Default Which wire do I use?
Hey all,
2004 H2 with the Navigation Screen/CD player. I am fixing to install the Ipod interface that plugs into the existing wiring but it needs to be tapped into a power wire and ignition wire. My question is when i pull the player out to tap these two wires into the factory wiring, what color wires will i be looking for? the wires i have now are the traditional red(power) and yellow(ignition) that come off of the ipod interface. will the wires i tap these in to be the same color? or a different color? thanks
Old Nov 19, 2008 | 06:45 AM
BMJM100's Avatar
Default RE: Which wire do I use?
Hi, This is the factory wire diagram that I have listed. It does not say which factory radio but all the factory wire harnesses should be the same.
Radio 12V
orange + radio harness
Radio Ground
black/white - radio harness
Radio Ignition
(Class 2 Serial Data)
This one you will have to run a wire from under your streering column to the radio area. Look for either pink or white wire for ignition (keyed)
oceanbrave
Jul 8, 2015 03:35 AM
Brent Whitfield
Feb 12, 2014 06:40 PM
jasontag
Apr 26, 2010 10:08 AM
kosaic
Sep 12, 2007 10:47 AM
bonzaiii
Nov 26, 2006 08:26 AM
