Window Switch
Old Dec 19, 2014 | 01:31 PM
rayfry08's Avatar
Default Window Switch
Anyone replace bulbs in the window switch? Pulled the switch apart and found only 2 bulbs. Sure I read somewhere on this forum that there were more but couldn't find them. What am I doing wrong?
Old Dec 19, 2014 | 04:22 PM
wfturner's Avatar
If you are talking about the driver side window switch, then there are only two bulbs.
You can order additional bulbs here,
Five 5 Bulb for 2005 2010 Hummer H3 Heater A C Controls Window Switches Mini | eBay
Old Dec 20, 2014 | 05:36 PM
Happy Hummer's Avatar
Yep. It is pretty straight forward if switch is already apart.
Chris
Old Dec 22, 2014 | 09:28 AM
rayfry08's Avatar
Replaced the 2 bulbs in the window switch and it works fine. Wasn't that hard and sure saved a lot of money. Dealer wants you to purchase the whole window switch. Thanks to forum members for the info on the bulbs and how to remove the switch.
Old Dec 25, 2014 | 06:28 PM
elmata's Avatar
Unhappy
Any reason the rear side window switch lights wouldn't come on after changing the bulbs? My front switch lights work but my rear switches wont light up, I replaced all the bulbs when I bought my 08 H3 last month. I did move the bulbs back up to the front to make sure they aren't bad and they light up but then when I move them back to the back two switches they won't light up. The switches will roll the windows up and down though.
Old Dec 25, 2014 | 06:30 PM
elmata's Avatar
Forgot to mention they weren't lit up when I bought it that was one of the reasons I changed them. One was burned out the other works fine I kept the good one just for a spare.
Old Dec 26, 2014 | 06:54 AM
rayfry08's Avatar
If the bulbs don't work, try turning them around 180 degrees. Someone on the forum suggested that and I tried it and it worked.
Old Dec 28, 2014 | 10:31 AM
elmata's Avatar
Thanks ill have to try that and get back with yall.
hummerhack
Dec 17, 2014 02:25 AM
WannaScoopaDis
Feb 7, 2013 06:06 PM
VividVisions
Apr 27, 2009 04:47 PM
ukpaul
Jan 5, 2009 07:56 PM
heavyD
May 14, 2008 04:52 PM
