Rear door won't lock
Old Dec 15, 2014 | 07:18 PM
Snakecharmer's Avatar
Default Rear door won't lock
2008 H3 Alpha - My rear door (not one of the side doors) won't lock. It does not lock with the alarm fob or with the driver's side door switch.
any suggestions?
Old Dec 15, 2014 | 10:32 PM
happythree's Avatar
Default very serious problem
ive mentioned this b4 and got ZERO answers! lucky you its not locked because there is no way known to open that door without a torch! unless someone comes up with it now that its a valid topic.
i tried (very carefully) to unlock it while open and locked with the remote, and could find nothing inside that would do it.
i consider it a major problem and id love to be proved wrong!!
i reached in and got pictures of the stuff in there and while rods do move , you cannot manually open the door.
hello gm???
in your case it may be a fuse or open wire but im talking about a perfectly good h3 where nothing can be done. check all wires, connectors etc,,,and pray lots.
Old Dec 16, 2014 | 02:51 AM
Happy Hummer's Avatar
Does the dic display any door messages?
Does the interior light stay lit?
If not it may be the actual mechanism itself or as stated the wiring.
Jmho
Chris
Old Dec 16, 2014 | 05:49 AM
- no door messages
- interior light does not stay lit
I will check to see if that mechanism is fused
Old Dec 16, 2014 | 06:17 AM
Pop the door panel off and see if the rod that goes go the electric solenoid is disconnected.
Old Dec 28, 2014 | 08:15 AM
- the rod to the solenoid is connected
- could not find anything listed on the fuse box that looks applicable
Anyone have any other ideas?
Old Dec 28, 2014 | 11:59 AM
happythree's Avatar
Default be careful, dont make it worse
this is not a simple problem, mentioned years back. no answers. if it gets locked you cannot get to it or get in.
hello gm??
hello gm???
DZLROKET
Jan 25, 2023 06:37 PM
ChevyChad
Feb 20, 2019 09:47 PM
Richard Huggins
Jun 12, 2016 08:11 AM
BrennMan
Dec 7, 2013 10:39 PM
Hurst
Nov 1, 2009 05:14 AM
