Will 4.56 gears from an I5 fit in an Alpha
Old Sep 18, 2011 | 09:35 PM
GulfCoastH3's Avatar
Question Will 4.56 gears from an I5 fit in an Alpha
I added 35's and noticed a little lost power at take off. Will 4.56 gears from an I5 fit my Alpha?
Old Sep 18, 2011 | 09:42 PM
drtom's Avatar
Banned
id guess u could swap out the diffs.
what gears are in the h3a?
ure gas bills will go up huh?!!
Old Sep 18, 2011 | 09:53 PM
I will be doing this "mod" soon enough. The 4:10s in our Alphas do OK with the 315s but after some calculations I see that moving up to 4:56s will put me back into the "sweet spot" for the 5.3L plus the low end will be once again outstanding (especially for wheeling)!
I don't forsee any negative change in milage. I actually think that the mileage will increase as it did in our XJ with 33s going from the 3:55s to 4:11 gears. Went up 2 mpg overall after the correct speedo gear was installed!!!
I am not sure if you will need any "new" carriers, shims or anything else if you use the Alpha diffs. I plan on swapping in entire diffs (front and rear) from our H3T Adventure (4:56s locked front and rear) before selling it. YES, we will be relacing it with another H3T, getting and Alpha this time!!!
Old Sep 18, 2011 | 10:00 PM
I believe Alpha's came factory with 4.10's... Also, came with beefed up front diff casing so planned on keeping the diffs. Just thinking about swapping the gears.
Old Sep 18, 2011 | 10:31 PM
drtom's Avatar
Banned
bigger job
Old Sep 18, 2011 | 11:26 PM
ANY, H3/H3T that came with either an Alpha 08-10 or a front locker 09-10 I5 Adventures and Alpha OffRoads have the Cast Iron Front Differential Housing.
I had it priced out a few months ago (I don't do re-gears and locker installs but I will do a front diff.) and they wanted just as much for the gears, install and locker as I could get the entire front diff. assembly complete with 4:56s and Eton locker. Might want to check the GM online parts places and see what the cost of a "complete CI diff" is compared to the re-gear.
Old Sep 20, 2011 | 03:28 AM
DAGKANA's Avatar
Or MU he could check w/ Brodie (ridgedemon.com) idk if he has any right now, but he did at one point...
Old Sep 20, 2011 | 12:21 PM
That is a good idea also. I don't think he has any right now but it is worth a try!
If you wheel your HUMMER, might as well put a front locker in there while they have the front diff open. It shouldn't cost anything extra for the locker install except maybe drilling a hole for the air line or electrical connection.
Old Sep 30, 2011 | 12:05 AM
thepakiman's Avatar
I have broken H3T 4.56 HC4 rear axel 90% prts are good has 8000 miles on it, let me know if you want to do the gear swap.
I am not sure if you will need any "new" carriers, shims or anything else if you use the Alpha diffs. I plan on swapping in entire diffs (front and rear) from our H3T Adventure (4:56s locked front and rear) before selling it. YES, we will be relacing it with another H3T, getting and Alpha this time!!![/quote]
Sound pro
Jul 30, 2011 05:43 PM
ar99kid
Jul 29, 2011 07:43 AM
CarlosC
Oct 23, 2009 10:54 AM
jklein
Nov 11, 2008 03:22 PM
mikeb310
Oct 1, 2007 03:21 PM
