Will 3 ton jack stands hold up a h3?
Old Feb 13, 2014 | 09:12 AM
Poweraidion's Avatar
Default Will 3 ton jack stands hold up a h3?
I want to paint my wheels and I have to take em off. I was wondering if a pair of 3 ton jack stands will be able to hold up the h3? I will be painting two wheels at a time so the h3 will be held up by 2 jacks stands and 2 wheels? Do you think it will work?
Old Feb 13, 2014 | 09:20 AM
happythree's Avatar
I think the h3 is 5000 lb. so lifting one end is about half that.
3 tons is 6000 lb huh.
Old Feb 13, 2014 | 09:42 AM
Ken06H3's Avatar
You really should use jack stands...
Old Feb 13, 2014 | 10:09 AM
As long as you do not get under it, you should be ok. If I were going to get under the 3, I'd go with heavier jack stands.
My 3 weighs almost 6000 #.
Old Feb 13, 2014 | 06:08 PM
rascole's Avatar
Max of 3000 lbs on a 12,000 lbs worth of jack stand. More than enough I would think.
Old Feb 13, 2014 | 07:05 PM
1- 3 ton (6,000lbs) jack stand will support the weight of the whole vehicle. Curb weight is 4,700lbs. 2-3 ton jack stands is sufficient when only lifting 1 end at a time. Lift it up, support the vehicle with your jack stands, then give it a shake/push, to find out if it holds, then take your wheels off. GL
Old Feb 14, 2014 | 03:16 AM
Don't forget to chalk the other side of the vehicle that has the tires still on the ground.
Old Feb 15, 2014 | 11:09 AM
rascole's Avatar
Chock.
Old Feb 15, 2014 | 06:34 PM
rsc's Avatar
rsc
Check!
Old Feb 15, 2014 | 06:38 PM
Chick?
Brodie
Hummer H2 SUT
21
Apr 2, 2025 07:29 PM
Tom @ Snake River
Feb 10, 2009 08:19 AM
importkiller
Sep 20, 2006 01:13 PM
efrainl956
Jun 20, 2006 12:24 AM
efrainl956
Oct 26, 2005 12:50 AM
