Will 3 ton jack stands hold up a h3?
I want to paint my wheels and I have to take em off. I was wondering if a pair of 3 ton jack stands will be able to hold up the h3? I will be painting two wheels at a time so the h3 will be held up by 2 jacks stands and 2 wheels? Do you think it will work?
I think the h3 is 5000 lb. so lifting one end is about half that.
3 tons is 6000 lb huh. |
You really should use jack stands...
As long as you do not get under it, you should be ok. If I were going to get under the 3, I'd go with heavier jack stands.
My 3 weighs almost 6000 #. |
Max of 3000 lbs on a 12,000 lbs worth of jack stand. More than enough I would think.
Originally Posted by Poweraidion
(Post 308276)
Don't forget to chalk the other side of the vehicle that has the tires still on the ground.
Chock.
Check!
Chick?
