Where to go through the firewall??
Old Feb 12, 2013 | 07:45 AM
1sBtrThnN0ne's Avatar
Default Where to go through the firewall??
Looking to hook up a set of Daylighters to my brushguard. Anyone know of a good spot or somewhat easier spot to run the wires through the firewall?
Old Feb 12, 2013 | 09:45 AM
R-code17815's Avatar
I ran 4ga. back to my power Inverter, the easiest way was to just drill a hole & put a grommet in so it never rubs the metal.
I picked a spot behind the battery & between the factory harness grommet and the master cyl. Just enough room to get your drill in, was rather simple.
Old Feb 12, 2013 | 09:55 AM
happythree's Avatar
Automatic trans, I drilled the same area,from inside,found a hole on one of two layers of metal where the clutch would go in a stick shift.Put a one inch hole and you're ready for the next job.
I cut a 4 in piece of rubber hose,stuck it in and put putty to fill the excess space,ez to pull next time.
accely
Aug 15, 2014 08:12 PM
drtom
Apr 14, 2012 02:18 PM
59bugeye
May 16, 2011 09:36 PM
jeepzjgrrl
Jan 18, 2009 02:01 PM
