wheel spacer
Old Jun 16, 2007 | 07:45 PM
Bennersj's Avatar
Default wheel spacer
Just installed my 35's and noticed the rubbing for the first time. So I went through the forums and read about using a 1" wheel spacer. Has anybody used them or know where I can order one for the H3?
Old Jun 25, 2007 | 10:51 PM
Hummer III's Avatar
Default RE: wheel spacer
I have not installed them but I'll intend to do so once I get my d i c k Cepek 35" tires
You can order them from http://www.ezaccessory.com/Wheel_Ada...6550-6550t.htm
let me know how ...
Old Jul 1, 2007 | 05:40 PM
Bennersj's Avatar
Ended up getting a pair from the local shop. Only 5/16 I believe, they did the trick and for $5 couldn't beat it. After taking the 35's off to put the spacers on I just hope the girlfriend never gets a flat while she has it. I told her don't even bother just call for help.
Old Jul 18, 2007 | 02:57 PM
telcobilly's Avatar
just got back from an aborted attempt to install different rims on my H3 but the inside of the wheel rubbed the calipers. I know spacers would have solved the problem, but Discount Tire won't install them. Apparently, they are bad news, can anyone shed light on this? I really wanted those rims and they were listed as a fit, but 1/4 - 1/2" of caliper metal disagreed...
Old Jul 20, 2007 | 11:24 AM
importkiller's Avatar
adding spacers that do not have a set of new lug bolts on them could be dangerous because they do nothing but move the rim farther out thus decreasing the amount of usable lug bolt threads you have left. Use too big a spacer and you will not have a safe amount of threads left for your lug nuts.
Old Jul 21, 2007 | 12:09 PM
mfish's Avatar
A 1" spacer sounds huge. When I put 19" rims on my benz they rubbed the shocks when I turned, so the tire shop installed ~3/16 spacer, it was very thin but did the job. Most of your larger chain shops wont install them. The shop I went to was in the ghetto but they had crazy good deals...which is a good secret, I saved a few thousand $$'s over the last 2 sets of wheels by taking a trip to the other side of the tracks. .
You can buy spacers on line and install them yourself too. Just google it.
28sNoRubs
Feb 24, 2015 09:36 AM
Indy
Sep 18, 2013 11:30 AM
Bullwheel
Jun 9, 2011 11:31 PM
2wheelmonster
Nov 15, 2009 06:16 PM
cigarlvr
Dec 21, 2007 07:19 PM
