Wheel Offset Advantage?
Old Nov 3, 2007 | 11:55 AM
2zRescue's Avatar
Default Wheel Offset Advantage?
Why does the H3 have such a high wheel offset? What advantage does it give?
Old Nov 4, 2007 | 05:43 AM
HUMMER DRIVER's Avatar
Default RE: Wheel Offset Advantage?
I'm guessing it spreads the wheels farther apart and that gives you more stability than a narrower setup.
Old Nov 4, 2007 | 05:15 PM
2zRescue's Avatar
But wouldn't a shorter offset just mean the center of the wheel is not as wide, not the edge of the tire? The only thing I can see is the pivot point for the wheel changes and the high offset allows for more room for the tire to move. Is this right?
Old Nov 4, 2007 | 06:58 PM
importkiller's Avatar
higher offset allows the use of longer halfshafts....wider stance, more track width with less stress than using shorter hlafshafts and negative offset.
TRK
Jun 3, 2016 11:01 AM
davyo
May 12, 2008 11:38 PM
moho
17
Apr 17, 2008 11:33 AM
vinestore
Dec 25, 2007 02:51 PM
vinestore
Dec 25, 2007 02:13 PM
