What can we use from Adventure Package?
Old Jul 18, 2007 | 10:46 AM
D VADER's Avatar
Default What can we use from Adventure Package?
I knowthe Adventure packagehas the 33" wheels, which doesn't interest me. But how about the shocks, springs and anti-sway bars? I'd love to reduce the lean in my H3X. Anybody got a feel for this?
Old Jul 18, 2007 | 10:51 AM
D VADER's Avatar
Default RE: What can we use from Adventure Package?
With the huge 33" wheels I bet they have bigger brake rotors to stop them!!
Old Jul 18, 2007 | 11:01 AM
Dennis's Avatar
Yo Bob..
The adventure package only involves ..Like you said, the 285 tires...Plus, a 4:1 Borg Warner transfer case, Locking rear Differential, Stiffer Shocks ONLY..everything else is the same as the base model..
Old Jul 18, 2007 | 11:14 AM
mfish's Avatar
I wish.
ORIGINAL: D VADER
Old Jul 18, 2007 | 11:17 AM
samvoiceman's Avatar
worth it if you wheel. I stared with a base 06 and moved up to a 07 adv. the locker is worth the money. If you don't wheel it,don't bother.
Old Jul 18, 2007 | 11:20 AM
That electronic rear locking differential is big time mochismo!!!!! The whole reason I have my '07 Adventure. No rocks to crawl in Michigan (really zero in the lower, you could find a few in the UP) but get your rig bogged down in the soft stuff and WOW does linking the two rear wheels together help. Works pretty good for clearing some fallen trees/logs too. For the Non-Adventure group.....the rear differential on the Adventure locks together only at speed under 20 mph according to the owner's manual. I never tried to go faster yet to see what it really does? When you are creeping thru rugged stuff, how fast can ya go anyway? Dennis hit the nail on the head, 33 inch tires, wheels are 16 inch, same basic H3, just a plus in the off road equipment. I only dreamed of having an electonic rear locker in previous 4x4s. Adventuring. J
Old Jul 18, 2007 | 11:37 AM
D VADER's Avatar
I'm confused. My H3 has 3 buttons on the dash. When I push the second button it seems to lock the differential. The tires chatter and scream a bit when I make turns. What gives?
Old Jul 18, 2007 | 11:41 AM
kild1's Avatar
us X guys have the 18 in.wheels
not the 16's
comes stock w/ the 265/65/18
i put 275/70/18 on mine which is about .4 inches bigger than the adv. tires
Old Jul 18, 2007 | 11:43 AM
Dennis's Avatar
ORIGINAL: D VADER
To quote F5Fstop from another thread..
The H3 is a full-time four-wheel drive system, that operates in a 40Fx 60R setup. If you push the 4wheel high LOCK button, you lock in a 50x50 which can transfer power and then you have the four wheel low lock, which drops the t/case to a different ratio.
Old Jul 18, 2007 | 12:02 PM
D VADER's Avatar
ORIGINAL: Dennis
ORIGINAL: D VADER
So it's not a true locker as in the Adventure package?
Also, do we have an overdrive for the highway?
