Water in tail lights
Old Nov 12, 2010 | 09:28 PM
Tomahawk's Avatar
Default Water in tail lights
I have a 2007 H3 that has been collecting water in the tail lights. Anyone else with this issue? How did you resolve it, if so?
Thanks!
Old Nov 12, 2010 | 10:42 PM
drtom's Avatar
Banned
start by drilling a small hole to let it out.
when u find how it got in , let us know!
Old Nov 12, 2010 | 10:44 PM
xllkoyokollx's Avatar
Its just two screws that hold the tail lights on. You can remove them and dump the water out. I haven't personally experienced this problem but I have taken the tails off a couple of times. When you have them off I would check for cracks in the seems. Once you find the source of the leak I'm sure some clear silicon would quickly remedy it.
Old Nov 12, 2010 | 10:46 PM
no definitely don't drill em. Do let us know when you find the cause.
Old Nov 13, 2010 | 12:08 AM
Mr_T's Avatar
Mine has had a crack in the passenger side since I bought it. Has a small amount of moisture but I haven't replaced it. If it's a seal problem, try using silicon. I'd just get ebay and buy a new taillight
Old Nov 13, 2010 | 05:22 AM
drtom's Avatar
Banned
one small hole at the bottom and the problem is gone
Old Nov 14, 2010 | 09:31 AM
I mean no disrespect but this is not true. It does not solve the problem it only alleviates one symptom. (A puddle of water in the tail light housing.) You still have water getting in there. This could lead to more problems down the line. as the water dries it will leave mineral deposits on the inside of the lense. (Granted this is very slight at first but will build up over years.) This will lead to poor light output. With no satisfactory way of cleaning this inside of the light housings this would lead to them needing to be replaced.
Old Nov 14, 2010 | 10:33 AM
drtom's Avatar
Banned
first,if the assembly shows no cracks the leak must be where the bulb plugs in, is it properly fastened.
you could run a bead of sealer above each bulb opening,diverting water away from the seal which may be leaking.
the small hole really should be a factory standard anyway. if you get enuf water in to cause a dirt buildup you must have a big hole somewhere and the little hole wont hurt till you fix it right or replace it.
if it gets really dirty u could dump in some soapy water and shake it up and hose it out!
a lot to do about nuttin!
Propst72
May 5, 2016 05:08 PM
LasseS
16
Oct 24, 2012 06:30 AM
Draketh
Jun 11, 2011 09:56 PM
rushl
Apr 16, 2011 09:41 AM
nicos
Feb 24, 2008 09:07 AM
