Water Leaks from ceiling above Front Windshield
I have a 2003 Hummer H2, and I have found a leak in the vehicle. It is running down the front windshield on the inside. I think it might be from the Marker lights, but how do you get those off to fix the seal. I heard they pop off, but it seems like it would break when I attempt to do so. Can anyone please advise. It rains a lot where I'm at and its actually sunny today. Thank you so much. oh, I have the adventure model, It doesn't have the moon roof.
Hi to remove the front middle 3 clearance lights go under the light and the weatherstriping on the side where the little slot is at the bottom with a thin piece of plastic or a small screw driver rapped in tape. Their is a release clip you push in on and the light will pop up.
Hi also check the 2 corner clearance lights unscrew them and lift them up. You will see a rubber gommet under them that the wires go through some times water can get inside the truck around the outside of the gommet but usally the water is in the corners of the headliner or down the pillar. Just use some rtv on clearance lights gaskets and around the gommets that will fix the water problem.
also keep in mind that the star screws that are on the roofrack may cause a leak,just take them out and clean them but make sure to put the small o-ring gasket on the star screw,all h2 hummers have this..if the leak keeps going then take the roofrack off,under that you will see a seam,just put some silcone on the seam from front to rear.just a friendley reminder.
Propst72
May 5, 2016 05:08 PM
HummerGuy
Oct 13, 2006 03:55 PM
