Truxxx Kit Question
Anyone with the Truxxx kit have any problems with klunking in the front sounds like the right side? I used the keys and the shock extensions and had the alignment done with my mechanic and ever since then I have had the klunking. Not sure what it is. Any input you have would be appreciated.
ORIGINAL: jbnjc123
Read all the way down to the bottom.
https://www.hummerforums.com/m_76985..._/tm.htm#76985
I am not getting squeaking but clunking when hard on the brakes, usually just once until on the gas again. I took it in to have it looked at and the keys, being painted like a rhino lining, were the problem.
Now that the lining has worn a little the noise is going away. I also sprayed some lube in the keys and the noise was totally gone.
I think once the lining is gone the nosie will go with it. BTW I got my new kit for $120. The install and alignment was another $120. Very pleased with the look andonce thenoiseis gone I will be a happy camper. Thanksfor the replies.
Mine used to do that in the beginning, then I had the shop that installed it add grease to the contact areas and the sounds went away. It's been 6 months without any noise, I'll let you know if it ever comes back.
H2Joe
Aug 2, 2008 10:01 AM
VICTORYREDH2
Mar 8, 2008 04:03 PM
ockie
23
Sep 14, 2007 11:11 PM
