tru cool trans cooler question
Old Aug 24, 2015 | 05:02 PM
Dieseldrums's Avatar
Default tru cool trans cooler question
Will the 4' supplied hose be long enough?
Old Aug 25, 2015 | 06:44 AM
alamry's Avatar
i did ask myself that exact same question when i got mine and the answer is yes.
Old Aug 25, 2015 | 07:21 PM
Old Aug 26, 2015 | 07:22 AM
H2Miami's Avatar
Be very careful while measuring and cutting the hose . I cut the first time 1 inch longer and didnt have enough for the 2 .
Btw make sure you tight the clams or use double .
Those clams seems to get loose over the time
Old Aug 27, 2015 | 05:40 PM
Thanks... I plan on using compression fittings
Old Aug 29, 2015 | 07:43 PM
Installed the Tru Cool today. I used the compression fittings shown. I took pics of the part numbers I got from Home Depot if anyone's interested. F-ed up my hands a little but temps went from 200+ to the gauge barely moving.
Attached Thumbnails tru cool trans cooler question-20150829_175203%5B1%5D.jpg   tru cool trans cooler question-20150829_191128%5B1%5D.jpg   tru cool trans cooler question-20150829_191131%5B1%5D.jpg   tru cool trans cooler question-20150829_191141%5B1%5D.jpg
Old Sep 16, 2015 | 11:03 AM
mulepic's Avatar
Thanks for the pictures, I'll try to use those fittings as well.
I just became the new owner of a 2008 (6l80) H2 and I will be putting in the tru-cooler tomorrow. What tranny fluid should I top-off with?
Old Sep 16, 2015 | 02:57 PM
ryaleon's Avatar
Dexron 6. Brand doesn't matter as dexron 6 is dexron 6 no matter what.
Old Sep 16, 2015 | 03:04 PM
mulepic's Avatar
Thanks. So I'll need a bottle or two of that and the fittings from home depot. From what I can find it looks like you have to swing the power steering cooler over and put the tru-cool right up against it otherwise the hood won't close.
I also read you can remove the tranny hoses from the radiator by removing a retaining clip. I just can't find any pictures.
Old Sep 16, 2015 | 03:07 PM
ryaleon's Avatar
When I did the install on my 04 I did have to swing the PS cooler over. But when I did it on my 08 I did not. Not sure why. And yes the lines going into the radiator are somewhat shaped like e-clips. You can use a flathead screwdriver to pry them off. There's little room to see or move in that space so if you have the right tools it's probably easier just to cut them.
