Transmission wont shift out of park
Old 04-25-2015, 12:26 PM
mexline's Avatar
Default Transmission wont shift out of park
Does anyone have any ideal of what the problem might be. The shifter is stuck in the park postion, the shifter release button is really hard to press
Old 04-25-2015, 04:19 PM
happythree's Avatar
shift solenoid under handle??
Old 04-25-2015, 07:18 PM
mexline's Avatar
Yes and thanks, I found it, just a loose connection. Corrected the problem and now everything is working.
Old 04-25-2015, 08:56 PM
happythree's Avatar
i completly disabled mine so i can shift anytime without brake or even the key.
Old 04-26-2016, 04:47 PM
Jeff Bartnett's Avatar
Had checked that earlier today. Looks fine but neutral safety switch on tranny (inhibitor switch) may be bad. Only say that because key doesn't remove when vehicle rolls forward a bit once in park. If I park on level ground key sporadically sticks and I have to restart engine, engage tranny, keep foot on brake, turn off engine and key then will releases to full off position Park does engage with no problem. Do u know if the problem with shifter can be caused by this going bad? Would that cause the low voltage issue I described earlier?
hmmrdude
Hummer H1
07-08-2022 01:45 PM
simota1
11-24-2021 12:45 PM
n0m4d
04-29-2016 01:14 PM
Kinghacker1234
11-06-2011 10:01 AM
Raffi76
04-28-2009 10:59 AM
Quick Reply: Transmission wont shift out of park
