Transmission Mystery
Old Dec 3, 2017 | 07:42 AM
ad4le's Avatar
Default Transmission Mystery
I have an 07 H3 that has developed a transmission problem that no one seems to ever have heard of. When it drive all is fine, shifts proper, etc. If I have to stop for any reason, it's like I shifted into neutral. I have to shut down & restart to resume driving. Called many repair places & searched the net but haven't found an answer. Seems like it must be some electronic module since shutting down & restarting corrects it. It doesn't matter if I'm in drive, 1, 2, or 3.
Old Dec 3, 2017 | 11:33 PM
Happy Hummer's Avatar
I'm going to ask some questions?
* Did you recently have any work done to H3
* Did you use your cruise recently ( if so is it stuck in on position)
* Did you or do you have a cell light on dash
Possible remedies...
* Battery cables are bad or connectors to battery
* 4x4 controls are stuck or funky
* Trans fluid and filter
* Trans wiring or solenoid's
* TCM is having troubles
Etc...
Old Dec 4, 2017 | 07:04 AM
ad4le's Avatar
No recent work done. Battery cables are good & snug..Don't use cruise control. What is cell light on dash? I'm afraid, if any, it's going to be the TCM. Taking to shop tomorrow. Will let you know the diagnoses.
Old Dec 4, 2017 | 09:49 AM
CEL = Check engine light.
2007s do not have a TCM, the trans is controlled by the PCM.
Miles on the vehicle would have been helpful.
Let me re-phrase a question.. Do you still have the crappy azzed OEM Battery Terminal Connectors? If so, replace them with an aftermarket quality set, like Stingers or your favorite brand. #1 cause for H3 electrical gremlins, the stock terminal connectors are complete junk and ALL of them fail, not if, but when.
Old Dec 5, 2017 | 08:10 PM
ad4le's Avatar
I stand corrected- PCM- thanks. They said at the transmission shop today that there is a code and it's electrical, possibly the pressure control switch. I will check the battery terminal connectors when I get it back & replace them too. Will let you know the outcome tomorrow, Their electric expert will be in tomorrow so they will let him trace out the problem.
Old Dec 8, 2017 | 04:42 PM
Tim McGarvey's Avatar
I just had the same problem with my 08 H3. The shop changed the auto trans fluid, and it fixed the problem.
jvorpahl
20
May 9, 2012 02:53 PM
Broken Halo
Aug 31, 2011 06:45 PM
cruisin
Feb 6, 2011 04:56 PM
HummerGuy
Jan 30, 2008 02:24 PM
blackstangs281
Jan 22, 2007 12:09 AM
