Transmission cooler recommendations???
I just purchased a 2009 H3 with an auto transmssion today. I sold my 2006 5 speed which always seemed to run hot.
I am in Phoenix and tow a flatbed trailer with ATV's on it so I was thinking it might be a good idea to install a transmission cooler on the new H3.
I got the tow package on my new H3. Does it come with a Tranmission cooler?
Are there any aftermarket transmission cooler recommendations out there?
Thanks~
Thanks~
I have a 07 with the tow package. The dealer told me there is no trans cooler needed and no difference in the radiator or transmission cooler with or without the tow package. Only the hitch and wiring harness are different.
I am assuming the tow ratings are low enough that the H3 is not modified for additional cooling with or without the tow package. I have looked all over mine for any trans cooler and there is none, other than the standard cooling lines from the transmission to the radiator like all other vehicles have.
I just purchased a 2009 H3 with an auto transmission today. I sold my 2006 5 speed which always seemed to run hot.
Thanks~
Thanks~
The transmission cooler is inside the radiator. There have been a few reports lately of these coolers failing and causing transmission failure as the coolant gets into the transmission. The fix is to add an aftermarket trans cooler and seal off the transmission cooler connector on the outside of the radiator.
It might void the warranty, but I am out of warranty and decided not to go with an extended one. I will likely add an after market trans cooler at some point. But for now, I'll make sure that I change the coolant regularly to prevent gunk from building up in their potentially causing a failure.
Humdinger2
18
Apr 23, 2018 08:40 PM
mb7050
Oct 15, 2010 01:24 PM
josh1899
Aug 13, 2008 08:48 PM
mastercraft88
Mar 23, 2008 01:20 PM
