Transfer Case Encoder Motor Replaced!!
Just a quick note : I was getting the "service 4 wheel drive" indication every time I started my 2004 H2 - I was worried that one day the transfer case motor would quit completely so I purchased a Dorman Transfer Case Motor #600-908 but it did not function correctly ( you have to change out and move the connector pins and I did not want to hassle with that )
I ended up purchasing this : ACDelco 89059688 GM Original Equipment Transfer Case Four Wheel Drive Actuator with Encoder Motor off Amazon for $218 and in less than 45 minutes my problem is solved!
Spend the extra $ for the original equipment actuator and if you have put the TC in neutral and the TC shaft does not match the new TC encoder motor just use a crescent wrench to move the TC shaft to match what the motor is set at.
No more codes, Hummer shifting perfectly !!!
help please
No more codes, Hummer shifting perfectly !!![/QUOTE]
Happy Hummer
Mar 10, 2018 10:34 PM
Knightblade
Nov 16, 2017 09:51 AM
