Trans issue
Old Dec 18, 2007 | 02:46 PM
Herm's Avatar
Default Trans issue
More often than not when driving the 97 TD when pressing the gas pedal to pass or go faster the vehicle will fell like its bogging down and not going into passing gear...any thoughts on this one??
Herm
Old Dec 18, 2007 | 09:21 PM
Default RE: Trans issue
My 97 TD went through a period where when I hit the pedal, mainly at highway speeds it sounded like it was spooling up or slipping before it would catch and start to accelerate. Replacing the nuetral safety switch and one of the electrical harnesses solved the issue. Not sure if that is what you are experiencing or not.
Old Dec 18, 2007 | 10:46 PM
Injunfarian's Avatar
kind of sounds like a injector or lift pump issue.
Old Dec 19, 2007 | 08:09 PM
hmcoleap's Avatar
I am with Injunfarian on this one -- need more detailed information on the problem, but first guesses would be bad diesel fuel, clogged fuel filter (when is the last time you changed it?), or constricted air filter. Next guesses would be lift pump, or other fuel delivery problems (injection pump, injectors, crack in fuel pickup tube)
Is it cold outside where you are? Could be fuel clouding if you don't have a winter additive in there.
Old Dec 23, 2007 | 10:02 PM
Herm's Avatar
Well the lift pump is brand new. also this happens in any weather situation..also the fuel filter is new..could it be the kick down cable?? or does it have one?
Old Dec 27, 2007 | 05:22 PM
Herm's Avatar
anyone with thoughts on this??
greg260
Jan 27, 2018 12:41 AM
SikFukinH3
Jan 29, 2012 07:56 AM
CAMARO
Aug 17, 2007 02:04 PM
whododat
Dec 2, 2006 12:30 AM
jonhbryson
Aug 28, 2005 02:11 PM
