Traction failure. stab system fault
Old Apr 7, 2015 | 11:56 AM
21LoLo21's Avatar
Default Traction failure. stab system fault
Hey y'all I went through the car wash yesterday. Left, got about 50 ft away and the truck bogged down and practically shut off (engine still running)but I couldn't go anywhere. My traction control and abs dash lights came on and the DIC started saying Traction control failure, ABS failed, Stab sys fault. Pulled over sat a couple min. Was able to go again, with it lurching then had no breaks. Drove perfect this morning none of the lights were on.no issues. The truck came with an after market lift. And the tire pressure lights and dic have been saying service tpm since I got it. The dealership told me that's due to the aftermarket lift and bigger wheels.
Old Apr 7, 2015 | 12:13 PM
DO YOU HAVE A SUN ROOF?
If so, do a search for leaking drain tubes. It will effect your BCM on the passenger side foot well. It gets wet things go krazy.
Old Apr 7, 2015 | 12:20 PM
21LoLo21's Avatar
Yes I do!!!! And I had to close the headliner because some water came in, you can also hear water running after I wash it, sounds like it should be trickling in the truck somewhere but I can't ever find it! #Amazing
Old Apr 7, 2015 | 12:26 PM
21LoLo21's Avatar
sorry what does BCM stand for?
Old Apr 7, 2015 | 01:09 PM
Body Control Module. It is behind the passenger side kick plate under the glove box. Search how to clean and/or unclog your sunroof drains.
Shorty
Jun 23, 2015 09:12 AM
Sramos091
Mar 29, 2012 09:04 AM
mosesjel
May 26, 2011 11:05 AM
brachilius
28
Feb 3, 2011 08:04 AM
