TPS. Code 21
Old Nov 15, 2011 | 08:24 PM
logicbyondreason's Avatar
Default TPS. Code 21
Experts-
I write to you because I am still battling some issues with my H1. A quick reminder: I own a 1995 6.5 NA that was having some tranny issues. I replaced the transmission and some of the symptoms of not shifting smoothly have vanished. As recommended, I ensured the grounding points were tight and the TPS was calibrated with the required block. I am now in a scenario where I get code 21 with the tranny stuck in safe mode. I hooked up the Tech1 with the engine off and watched the TPS voltage and % jump around and never settle down. Also, after applying the throttle it seems to get stuck at 35%. Following the manuals troubleshooting instructions I have checked for voltages and shorts. One of the last parts for troubleshooting code 21 is to jump two pins on the TCM, which I did. The result did not show a voltage greater than 4.9v per the tech manual and is hinting at a bad TCM or a possible short/ground. Have you seen symptoms like that which lead to a bad TCM? Can a TCM be tested at a dealer? Where can I buy one? How much are they? Any suggestions/tips? Part numbers? I do not have any wiring diagrams for the truck except the one for the transmission. Any help would be appreciated. Thank you in advance.
Very Respectfully,
Pavel
Alex2012
Oct 1, 2012 01:53 PM
Oni
Jan 30, 2009 04:17 PM
dantstk
Jan 6, 2009 02:35 PM
triplej2k6
Oct 27, 2008 12:28 PM
HummerGuy
Apr 13, 2008 05:17 PM
