TPM question
Old Jan 22, 2013 | 09:26 PM
bigshow1970's Avatar
Default TPM question
Hey guys,I was wondering if the spare on my H3 came with a TPM sensor so I can do a 5 tire rotation. If not can one be installed to do a 5 tire rotation.
Old Jan 22, 2013 | 11:59 PM
If your valve stem is not rubber then it may have a TPM. Take a look at the other rims and you can see what I am talking about.
From the factory GM stopped adding them to the spare in early 07. That does not mean that the previous owner didn't add one.
Old Jan 23, 2013 | 09:06 AM
Thanks for the info Tainter,So if I add one to the spare then the spare pressure will be checked as well as the other 4 with no problems. Nice to know. Why haul around full size spare and rim if you cannot rotate it in!!
Old Jan 23, 2013 | 09:40 AM
Bunger's Avatar
Originally Posted by bigshow1970
...,So if I add one to the spare then the spare pressure will be checked as well as the other 4 with no problems.
No, only the 4 actually on the ground are monitored.
There is a learning procedure to follow after rotating the spare into the mix.
The H3 learns the 4 on the ground and ignores the spare.
Procedure is in the owners manual.
Old Jan 23, 2013 | 10:10 AM
Well, if you do not have a full size (same size as the other 4 on the ground) with a FT AWD/4X4 H 3, you do not have a spare. You can't use a mini or different size. Nothing stopping you from rotating in an un-monitored tire, back when people had brains, no cars had tire monitors and we still managed to drive them.
BTW, I never rotate in the spare.
jm4490
55
Nov 8, 2015 06:24 PM
lucky19942001
Oct 18, 2014 09:39 AM
jvorpahl
May 20, 2011 04:16 PM
melvynray
May 11, 2010 12:45 PM
NoDakH3
Feb 13, 2009 09:08 PM
