TPM question
If your valve stem is not rubber then it may have a TPM. Take a look at the other rims and you can see what I am talking about.
From the factory GM stopped adding them to the spare in early 07. That does not mean that the previous owner didn't add one.
Thanks for the info Tainter,So if I add one to the spare then the spare pressure will be checked as well as the other 4 with no problems. Nice to know. Why haul around full size spare and rim if you cannot rotate it in!!
There is a learning procedure to follow after rotating the spare into the mix.
The H3 learns the 4 on the ground and ignores the spare.
Procedure is in the owners manual.
BTW, I never rotate in the spare.
melvynray
May 11, 2010 12:45 PM
NoDakH3
Feb 13, 2009 09:08 PM
