Towing with my H3
Old Jun 25, 2011 | 05:43 PM
wkrpinnick's Avatar
Default Towing with my H3
Do any of you guys pull trailers or boats with your h3? Im looking to get a 15ft or so pontoon boat . Not a long trip to the lake maybe 50 miles.. will the h3 do the job. not sure of the wait . but i have a friend with a good size ski boat he said it does a good job.
Old Jun 25, 2011 | 06:03 PM
Songman's Avatar
I pulled a loaded U-Haul trailer from Central CA to Southern TX with my I5 with no problems at all. Even that long uphill grade into Albuquerque was a breeze. I even still got 15.5 mpg with the trailer.
Old Jun 25, 2011 | 10:24 PM
JCA1981's Avatar
From: The Empire State... should be called The Nanny State
Should be no problem at all. I pulled my friends 18' Boston Whaler and I have the 3.7L I-5. I do a heck of a lot of towing. Pulled other cars on a dual-axle car hauler, both my bikes with a dual axle-utility, and the U-Haul 6x12 like Songman was talking about above from Philly to Brooklyn. (His trek was a lot longer than mine though). H3 pulled all of it with abs. no problems. Out of all of that, the Whaler had to be the easiest and lightest loads.
Just make sure your trailer has the correct weight ratio esp. if you have the outboard attached to the back. The bow is going to weigh nothing so most all of the weight will be in the stern. If it's incorrectly weighted the outboard will create too much weight in the rear and want to act like a see-saw with only one person on it.. the trailer will want to try to pop itself off the hitchball.
Let us know how you make out.
Old Jun 25, 2011 | 10:49 PM
Songman's Avatar
You'll probably need a drop hitch too. I used a 3" drop but probably would have been better off with a 4".
Old Jun 26, 2011 | 08:57 AM
Widespread Hummer's Avatar
I have pulled a 19' I/O boat a number of times with no problems. Have used steep ramps as well, no problems. I have a 2" drop hitch
Old Jun 26, 2011 | 09:14 AM
thedave8's Avatar
did your H3 come with towing package and already have a hitch? I may move soon, but not sure if I can tow my wifes dodge caliber with my h3....mine doesn't have a hitch or anything.....trailer it or dolley wheels?
Old Jun 26, 2011 | 09:51 AM
wkrpinnick's Avatar
Default no towing package installed
Sounds good guys sounds like it will do what i want.
thanks for the help
some one posted after market or oem will take there advice..
Old Jun 26, 2011 | 10:49 AM
Songman's Avatar
Mine is the factory towing package.
Old Jun 26, 2011 | 11:04 AM
jdbaker73's Avatar
I've got the factory towing package and tow a 21' pontoon boat almost every weekend, it does fine, but wouldn't want to tow up a mountain. 07 I5 w/adventure package
Old Jun 26, 2011 | 11:21 AM
wkrpinnick's Avatar
Rock on ! no mountains out here in central kansas..
