Towing Issues
Old Mar 28, 2011 | 07:46 AM
poppee59's Avatar
Default Towing Issues
I bought a travel trailer to drag along behind my H2 and my only problem is the outside spare tire, which, as most know, hangs on the outside of the rear door. It gets in the way of the crank for the trailer....can't even hook up. I took the tire off and still the bracket is in the way. My option is, remove the outer hardware for my spare and throw the tire in the back...not my first choice...any suggestions? I can't use an extender because then you can only haul 65% of your towing capabilities. My trailer is 4300lbs not loaded, so the 65% would hurt me.
Thanks for any suggestions.
Old Mar 28, 2011 | 09:54 AM
Songman's Avatar
My first thought is electric tongue jack. $79 and problem solved.
Amazon.com: 3000 lbs Electric Power Tongue Jack RV Trailer Camper (PJ3000): Automotive
Old Mar 28, 2011 | 09:48 PM
poppee59's Avatar
After talking to several hitch shops today, I'm inclined to agree with you. Thanks.
Old Apr 1, 2011 | 04:04 PM
atv jr's Avatar
If you use a weight distributing or leveling hitch with spring bars you can extend the hitch head back on an extended insert with no hitch weight penalty.
The spring bars are actually "picking up" the back of your tow vehicle and putting more pressure on the front axle. This is how all the big campers are towed.
A good hitch shop should be able to fix you right up.
Old Apr 1, 2011 | 05:38 PM
atv jr's Avatar
You do have the factory installed equalizing hitch on the truck, don't you.
If you do not have an equalizing hitch, any hitch shop can put on on. If you do have to get one, get one rated for 10,000 lbs. Then you will never have to worry about your tow load.
Old Apr 2, 2011 | 07:47 AM
poppee59's Avatar
Doing the leveling hitch today- thanks to all!
Old Apr 2, 2011 | 10:36 AM
atv jr's Avatar
daniel_hache
May 15, 2008 01:22 PM
dave85c4
Mar 15, 2006 05:24 PM
usmcman001
Jan 26, 2006 05:38 PM
ty_r1
Oct 25, 2005 03:47 PM
Syd R
Oct 5, 2005 06:04 PM
