Towing 10,000+ lbs...no problem
Old Nov 13, 2015 | 09:17 AM
ryaleon's Avatar
Default Towing 10,000+ lbs...no problem
Towed the most weight I ever had with the H2 yesterday. Easily over 10k lbs. Trans temp never got over 130F with outside temps in the mid 60's and i could go up hills at 70mph just as easily as if I was unloaded. Only issues was how much it had me sagging in the rear.
Old Nov 13, 2015 | 11:05 AM
honda400ex2003's Avatar
its too bad that trck just barely fit on the trailer. you could have moved it back and helped out with the sag a bit.
what did you get for mpg's towing? im curious since i get about 8.5 with mine lifted. any mods done to it besides the tires and light bar?
nice job!
steve
Old Nov 13, 2015 | 01:05 PM
ryaleon's Avatar
Yeah we were supposed to get a car hauler from a friend but it didnt happen. I have a magnuson supercharger and 4.56 gears.
I didn't measure fuel economy but my dic didnt change at all. Nor did it seem like I used anymore than I normally would for the distance I went.
Old Nov 13, 2015 | 02:22 PM
good to hear! glad it went well for you
steve
Old Nov 13, 2015 | 02:36 PM
ryaleon's Avatar
Does anyone know if the 08-09 and 03-07 have same class hitch?
Old Nov 13, 2015 | 11:50 PM
Synthetickiller's Avatar
All that I found was this short description of the frame on lynch hummer's old site.
Looks like that's for the 08/09 models based on GVWR.
Hummer H2 Chassis description.
The hydroformed, short rear-frame section helps create a high departure angle. It is heavily reinforced in key areas for H2's 8,600-pound GVWR capacity. The rear section incorporates a standard, integral trailer hitch receiver. Unlike with most SUVs (whose hitch receiver is added on), the H2's is built right into the last crossmember of the frame rail and developed into the bumper. A Class 3 trailer hitch is standard.
I'd assume (could be wrong) that the H2 would have the same hitch as Chevy 2500s of the same year.
franzu666
Apr 20, 2014 12:43 AM
luda81
Oct 10, 2011 06:19 PM
MRDM1
27
Oct 28, 2007 09:45 PM
RickLF
Aug 23, 2007 09:19 PM
xLusi0n
Aug 8, 2006 05:54 PM
