too lean at high RPMs. Tried lots of things. Ideas?
Old Mar 21, 2013 | 10:32 PM
rpalatine's Avatar
Default too lean at high RPMs. Tried lots of things. Ideas?
Hi, My 2006 H2 with supercharger, headers, cam swap runs lean on the dyno at high rpms. We've tried Boost-A-Pump, new stock fuel pump (old one had 85k miles) but nothing. Any ideas? thanks!
Old Mar 22, 2013 | 10:43 AM
rpalatine's Avatar
Default update
just leaving a trail so folks coming after me know what happened when they find my skeleton at the end of the trail. The hypothesis now is that the problem seems to be caused by fuel delivery. The stock pump cannot keep up to the power level. So we're modifyng the fuel bucket to accept an Aeromotive 340 pump and with the addition of the boost a pump we're hoping it's good.
Old Mar 22, 2013 | 11:20 AM
H2CANEPADESIGN's Avatar
Mine is supercharged also. I have the Magnuson kit. There is a Secondary fuel pump that runs inline with the stock pump to increase fuel pressure. the kit came with bigger injectors and fuel rails. Summit racing sells walbro hi-pressure inline pumps. I believe that mine was a gsl391? When my stock pump failed @ roughly 100k I replaced both of them. the second time around I used a GSL392. The first one pumps roughly 190 liters per hour. the second was around 255 liters per hour so no fuel starvation issues and it helps keep internal engine temps down.
Old Mar 22, 2013 | 11:22 AM
They do whine a bit when they get hot. try to mount it in an area that is not near anything that radiates heat or heat wrap the pump before you mount it if that is unavoidable. I mounted mine above the front cross member and wrapped it.
Old Mar 24, 2013 | 03:40 PM
rpalatine's Avatar
Default thanks
We'll see what happens
topkicktech
54
Nov 25, 2011 02:41 PM
Brianb
Aug 20, 2010 09:09 AM
psych0
Apr 28, 2010 07:25 PM
2007H3
Jun 18, 2007 11:10 AM
bmbenear
Jan 1, 2007 05:56 AM
