Tires Sticking Out
Old Sep 16, 2010 | 01:17 PM
MushMan13's Avatar
Default Tires Sticking Out
Im putting on 315/75/16s this week.. I have seen a number of pics where it appears when looking at the H3 from the font angle, that the tires stick out the sides a few inches, and I like the way this looks. Is this just from the tire being larger or is this something you can have done? Thank You!
Old Sep 16, 2010 | 03:36 PM
85_305's Avatar
Banned
35's are gonna stick out about an inch due to being so wide.
Old Sep 16, 2010 | 06:16 PM
Mr_T's Avatar
The tires are wider. Also depends on the offset of the wheels you put on. The stock wheels are +38mm. If you get anything with a lower offset they will stick out further. I'm in the process of customizing some wheels with a 0mm offset to fit my H#. Had them mounted the other day and they looked sweet. I'm having the inside of the wheels drilled out to mount flush on the hub so the lug nuts will tighten safely. I'll post pics when I finally get them on. I'm getting 33's or 35's in the near future also.
Old Sep 17, 2010 | 10:26 PM
Surfincoastie's Avatar
my 35s stick out about 1.5 inches with the offset
Old Sep 17, 2010 | 10:47 PM
Shakedown St.'s Avatar
Cool
Yep we had chunks flying into the interior when the Duratracs were clearing out yesterday!!
Old Sep 18, 2010 | 12:02 PM
slumlord's Avatar
I learned over a ear ago to roll my windows up in the mud after I got my 315 cooper sst's. I even had tennis ball sized chunks all over the top and sunroof. It will fo sho sling some stuff now. I also had to put 3/8's spacer plates between the wheels and the hub to stop stabilizer bar rubbing at full turn lock. You don't have to do anything. They gonna stick out cause they wider. 12 or 12.5 on most 35's...
Old Sep 18, 2010 | 03:17 PM
ya, my duratracs were slinging mud very easily when i went to the Pine Barrens last weekend
Attached Thumbnails Tires Sticking Out-48325p893475p983475p93475p938475p93475.jpg
Old Oct 31, 2010 | 07:32 PM
sheb's Avatar
do you have any lift on your h3 it looks great,i think i just changed my mind from a 20" rim to something smaller,it looks strong,i work with a piney where in the pines do u live
Old Oct 31, 2010 | 07:45 PM
Mr_T's Avatar
I agree. I personally didn't want anything bigger than an 18 and just ended up getting aftermarket 16's with a lower offset. I love the stance it gives my Hummer. Looks tough!
Old Oct 31, 2010 | 08:33 PM
no, that is the stock suspension with the tbars adjusted 2in. i actually live in delaware and go up to the pine barrens every month
