Tire TPM warning light...
I've had my 2006 h3 for about 3 months (50k miles). I've had to put some TLC into it - so far nothing too costly. Recently, I had two new tires and new brakes put on it. A month or two before that, I had a tire getting low - which was repared shortely after I got it, but the light continued to stay on. During the tire rotation and new tire addition, everying is great - tire pressure, etc. The tire place I took it to can't seem to get the annoying flashing warning light on my dash to go off. They suggested I try driving it a while (which is what they told me when I had the one tire repaired) and thought it would go off then - it never did.
I took it to get the oil changed after picking it up with the new tires and new brakes and asked the valvolene oil change guy about it - he kinda said the same thing - "you need to drive it a while at consistent speed... then it will go off" This was about a week ago and I've driven highway miles, in town, everywhere - and it's still on.
Any suggestions?
Any suggestions?
Is it the low tire warning or TPMS malfunction warning? if it's low tire I'd try deflating them a little then filling them back up sometimes this works. Or maybe the sensor got messed up when they put the new tires on, some of the tire places aren't real carefull when it comes to TPMS sensors.
all the TMPS info starts on page 5-59
http://www.gm.ca/media/owners/manual...nual_en_CA.pdf
I had a similar problem. above the mileage in the onboard display area it said "TPM SERVICE". I brought it to the dealership since I am still covered by the manufacturer warranty. They said they just had to clean the sensors. Dunno if thats what they really did or what but no more lights.
I am about to get new rims so hopefully it doesnt come back when the new rims go on.
look in your owners manual and it will tell you how to reset the sensors.... i just had to do it to mine... after you reset them and it goes as the book shows, you will have to drive around for a little bit and THEN it will go off... or if you even let it just sit for a little while it will work... the main thing is to go by exactly what the manual says and it will work fine...
________
Medigap forums
________
Medigap forums
One of my sensors was destroyed by NTB when they put my 35s on. Go through the programming process in the manual, if any one of the sensors won't register during the programming process, you could have a bad/broken sensor like I did. Don't expect any tire shop to have a clue on how to do the programming.
So if I had a second set of wheels/tire for the weekends I choose to go off-road, would I need the sensors on those? Or could I just live with the light/warning until I put the stock wheels/tires back on.
________
Honda Research America specifications
________
