Tire pressure warning
Old Mar 31, 2009 | 08:32 PM
mikehartigan's Avatar
Default Tire pressure warning
I was greeted with a low tire pressure warning Sunday evening. A visual inspection suggested that it wasn't an emergency, so I decided to let it go until next weekend. I've kept an eye on the tires just in case it turns out to be a bigger problem, but the warning went away this evening. I pulled out my pressure gauge and everything seems fine. Assuming I'm not a victim of a vigilante tire patcher, what's my next step?
Old Mar 31, 2009 | 09:11 PM
This has been the topic of many threads.
However, since you asked.... it is improtant that all four tires be set exactly the same cold. If you set them all at 38PSI you will not have an issue. Most of the time when you get a TPM issue, it is because you had the tires inflated too low. It is the consensus that 35PSI is the minimum to avoid false warnings. If it is cold at night, and you go off to work in the morning, one or more tires can be below the rest and set off a false alarm.
The entire TPMS is just a useless PITA.
scared2buy
Jan 30, 2011 05:48 PM
psych0
Sep 16, 2010 05:35 AM
NJHummer18
Apr 8, 2009 04:37 PM
NIK1
Dec 8, 2008 11:44 AM
djbrow3
31
Jul 27, 2007 07:36 PM
