Tire fit with no rub??
Old Mar 9, 2008 | 08:23 PM
StealthHummer's Avatar
Default Tire fit with no rub??
Hey guys, I have an 07 H3 and I want to put KMC Rockstar 20x10 rims. I wanna put on 305/50/20 Nitto Terra Grapplers but I was wondering if i will get any rub problems and if it will change my speedometer or mileage meter?
Old Mar 9, 2008 | 08:30 PM
HUMMER DRIVER's Avatar
Default RE: Tire fit with no rub??
I don't think those will rub. Your outer tire diameter should be around 32" with those numbers. 305mm = 12.0" then 50% of that is 6". Take the 20 rims and add 6" to the height times 2= 32".
However, depending on the offset and backspacing you may rub a control arm or the fender edge Also make sure they clear the caliper too! I've got 34"s on mine with no lift and the only light rub is a full lock either direction an the lugs just scrape the fender down by the mud flaps.
Old Mar 10, 2008 | 05:45 PM
Ok thats good to know thanks
cjlv_1
Dec 28, 2011 06:42 PM
Diablito
22
Nov 17, 2011 03:04 PM
deser27
Nov 13, 2007 05:58 PM
Brad_P
Oct 13, 2007 03:29 PM
WhtRatCop
Jun 26, 2007 06:43 AM
